It is currently Thu May 28, 2026 2:34 pm
 Post subject: MC push-rod installation
PostPosted: Sun Sep 30, 2012 9:37 am
The rubber bushing (FSM calls it a ring) -
Do you place it in the cavity in the back of the piston and push the push-rod into it?
Or do you put it on the push-rod before insertion?
I can't find this detail in the factory service manual, and I can't remember how I did it once years ago.
63 Signet / 10 inch front drums / weber 2bbl / HEI / 2.76 rear end
PostPosted: Sun Sep 30, 2012 10:39 am
Put it on the MC rod and then use your foot to "press" it into the receptacle in the MC with your foot on the brake pedal.
a bit of light oil or slippery vinyl treatment will help the rubber not get chewed up / destroyed during this process.
I am no0t sure if this is the "correct" way to do it, but I have many cars with this process done on and no problems!
PostPosted: Sun Sep 30, 2012 12:00 pm
6 Pack Dart
"Do you place it in the cavity in the back of the piston and push the push-rod into it? "
That is how I do mine, a small amount of something slippery (water on the hole)!
Richard
PostPosted: Sun Sep 30, 2012 12:58 pm
I put it on the MC rod and I did feel a "pop" when standing on the brake pedal, but it did not link up.
PostPosted: Sun Sep 30, 2012 1:45 pm
Not all master cylinders have the grooved recess for a manual brake pushrod.
PostPosted: Sun Sep 30, 2012 2:12 pm
I think this one does. *
It is a Raybestos MC36221.
I took the MC off the firewall and I am starting over with bench-bleeding.
The rubber bushing still looks undamaged...
It came with a new rubber bushing, but now I wonder because it looks like it might be a power brake-type without the recess.
http://www.slantsix.org/forum/viewtopic ... ht=mc36221
http://www.slantsix.org/forum/viewtopic ... 1&start=15
I bought the MC several months ago (no time to install) and painted it with Eastwood brake grey, so I own it.
Anyone want a barely-used master cylinder, cheap?
*or maybe not
PostPosted: Sun Sep 30, 2012 3:30 pm
OK.
I compared the backs of the old and new MCs.
The 36221 has a similar recess and step, but bigger diameter.
The 36221 piston is held in with a metal shipping tab or the rubber boot retainer. No e-clip.
The piston on the old MC has an e-clip retainer.
So, what is the best way to clear out the brake fluid from a master cyl so that you can ship it?
I guess I need a 36338 to get a 15/16 bore like my old one.
PostPosted: Mon Oct 01, 2012 7:59 pm
It really looks like the new MC would work with an oversize rubber ring.
The stock one has a .475 OD, and it looks like a .5 OD ring would lock the rod in.
I think I will experiment with some heatshrink or electrical tape next weekend.
