It is currently Mon Nov 30, 2026 3:53 am
 Post subject: Exhaust leak?
PostPosted: Thu Oct 04, 2012 7:16 pm
an exhaust leak will be audible in drive as well as neutral correct? If in drive, the exhaust leak becomes louder as i accelerate, when i switch to neutral and rev the engine to the same rpms, the sound should be there as well right? does it become louder in drive because the engine is under load?
70 Plymouth Valiant 4dr
PostPosted: Thu Oct 04, 2012 9:17 pm
Where are you thinking you have a leak?
PostPosted: Thu Oct 04, 2012 11:03 pm
I hear a tick tick sound while accelerating, sometimes it goes away as the car warms up. The tick sound reminds me of a cracked manifold I had once. I double torqued the bolts, checked for leaks. noise still there. No changes to engine. Sound just appeared one day. Manifold to head?
PostPosted: Fri Oct 05, 2012 1:52 am
Could be valves?
PostPosted: Fri Oct 05, 2012 2:03 am
Are you sure the manifold isn't cracked?
Sound going away after warm up sounds like a crack to me (heat expansion seals the leak)
Or a header pipe crack/leak
PostPosted: Fri Oct 05, 2012 1:22 pm
A little bit of trans fluid down the carb should smoke out the crack? The heat expansion makes sense. I just wonder why only in drive?
PostPosted: Fri Oct 05, 2012 1:27 pm
There's more exhaust flow and backpressure in drive.........
PostPosted: Wed Nov 14, 2012 1:07 am
the leak has progressively gotten worse. it's coming from the back exhaust runner. it is very loud and very noticeable. i gooped it as a temporary fix. as this is my daily driver i figure i'd purchase another head to do the work on. that way i can get the swap done in one day. going to pick up a head from board member kielbasa next tuesday. plan to do some port matching and a little polish. getting the engnbldr valves, and cutting the head a bit. i figure if i'm pulling the manifold off to put a new gasket on, i might as well pull the head, i'm already halfway there :P
Users browsing this forum: Bing [Bot] and 5 guests
