It is currently Thu Jun 04, 2026 7:08 pm
PostPosted: Sun Oct 07, 2012 5:07 am
Three on the Tree
hi Barry here.i got this low hum that seems to be near the water pump/harmonic balancer area...when you give it just a little throttle it goes away.its when it sits in idle you will here this .any ideas .Dan?..thanks and God Bless.Barry..ps. could it be the alt.?usually they sqeal though right?
1967 Dodge Coronet 440. 225cid. 3 speed column shift.radio delete
PostPosted: Sun Oct 07, 2012 8:36 am
With engine cold remove your accesory belts and start car. Check to see if noise is present. While doing this don't let it run very long because you have the water pump not circulating coolant with the belt off. If the noise is gone it is an accessory. I like to pull start accessories to check for noise. Wrap (do not tie) a thin rope around pulley a few times and then give the rope a good tug. As it unwraps it will spin the pulley and you might be able to hear your noise. This method works on water pumps, ac compressors, and alternators. Ps pump have too much resistance for this method. Good luck
PostPosted: Wed Oct 10, 2012 3:11 am
See if the trans cooler lines are hitting the engine.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Oct 10, 2012 6:23 am
Three on the Tree
hi Barry here.i have a manual trans.3spd.i now cant do anything till i get my rad.fixed its leaking at the top."seam".but thanks to all and God Bless Barry
