It is currently Thu Jun 04, 2026 1:44 pm
PostPosted: Tue Oct 09, 2012 5:54 pm
Hey guys newbie slant sixer here! After finding a super six setup including the carb and kickdown linkage I took off the old manifolds and upon a side-by-side comparison found out that my parts are pretty much the same, except the carb. Anyway, I decided to go ahead and take the head off to get new valve guides and seats, 3 angle valve job and also had it milled. 020'' for a little higher compression. Now it's time to put it back together, and I have misplaced all kinds of random nuts and bolts. Is there a 'top end' hardware kit available? If there are several, which is best? Thanks!
1977 Dodge D100 standard cab long box, 225ci l6, Holley 350 2bbl carb, late 60's Dart 2bbl intake and exhaust manifolds nicely ported, fresh valve job and valve adjustment, comp cams hi-energy pushrods, 020'' head mill, all VR gaskets.
PostPosted: Tue Oct 09, 2012 7:05 pm
Site Admin
Specifically, what is missing?
CJ
PostPosted: Tue Oct 09, 2012 9:14 pm
Well originally the two studs on each end of the manifolds were broken off in the head. I had those machined out, but needless to say, the triangular washers on the front and back of the manifolds are missing, as there were no studs to put them on. I'm not exactly sure how many I need total, but i have 10. I also have two conicalwashers, but I'm not too sure exactly which studs they go on. The other bolt I know I'm missing is the one that holds the (not sure what it's called) teardrop shaped deal to the head. Ultimately I would like to find a top end hardware kit if possible, that includes all the nuts and bolts like head fasteners, the bolts that hold the carb on, etc. Suggestions? Part numbers? Please and thank you! [color=blue[/color]
PostPosted: Tue Oct 09, 2012 9:55 pm
6 Pack Dart
http://www.dutra.org/doug/draft-webpage ... ctions.htm
You will find this if you click "Home" then "Articles"
Richard
PostPosted: Wed Oct 10, 2012 5:44 am
Thank you. Thats helpful :wink:
Users browsing this forum: curmudgeon, MDchanic and 4 guests
