It is currently Mon Jun 22, 2026 8:36 am
 Post subject: Valve Spring Seats
PostPosted: Mon Oct 15, 2012 8:10 am
I'm looking at running a different set of valves, but the new valve is .060" shorter than stock. Any issues machining the spring seats .060" to accomodate the change in overall length?
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
PostPosted: Mon Oct 15, 2012 8:59 am
I have wondered this same thing, but have not gotten confident answers from head experts. 0.060" may be OK, but you might want to experiment with a junk head first. You can always use Ford or Chev SB V8 valves, which are about 0.100" longer...
PostPosted: Mon Oct 15, 2012 9:48 am
I wonder if a recessed retainer would cure any potential problems...
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
PostPosted: Mon Oct 15, 2012 10:28 am
Car Model: 64 Valiant
Is your valvetrain going to be adjustable or non-adjustable. The tip height could also be .060" shorter as well and cause issues if your using a non-adjustable rocker arm.
PostPosted: Mon Oct 15, 2012 5:42 pm
Adjustable
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Pick 2!
