It is currently Wed Jun 17, 2026 9:50 am
 Post subject: 904 pullout
PostPosted: Sun Oct 21, 2012 1:53 pm
after looking the oil filter condition i have decided to pull the Trany out of the car. i know i will not get any single part in Karachi but i will try to do swaping some parts from different new model tranys.
this is oil filter
Trany coming out of my Duster
I did not found 904 on bodey instade i found this
this is the cooler bypass which probably cause trans burn out???
I will fix some local cooler made by Hyundai pickup truck.
and at last this is the hero alone took the trans out from my car with out any special jacks or tool.....
I am searching from ebay Australia full kit of my transmission..... can any one guide me.... lot thanks... :wink:
PostPosted: Sun Oct 21, 2012 1:57 pm
I searched the eBay Australia site and all the 904 rebuild kits I found actually ship from the United States.
PostPosted: Sun Oct 21, 2012 2:16 pm
Posted: Mon Oct 22, 2012 1:57 am Post subject:
Actually one of my friend is going to Sydney in this month and agree to bring parts for me. the only shipment to Karachi is itself 100+ doller told by Ceej last month. means 90 doller thing i willget in 200+ doller .
Thats why i wana know if i get in Sydney may be it will be bit cheep to me. other wise i am planning some thing else...
PostPosted: Sun Oct 21, 2012 2:18 pm
If you have a friend willing to bring it to your from Syndey, then it will likely be cheaper to purchase the parts through Australia eBay.
PostPosted: Sun Oct 21, 2012 2:27 pm
Dear Reed,
actually he told me give me the link of Ebay australia of your required parts, and i will buy online when i am in Sydney and bring it to you.
now can you tell me from exactly how and from where he can buy 904 kit from Sydney ...
by the way is this my trans is 904 ? because i found 111-4 number on bell mouth (u can see in pics)
Thanks for help in advance. :wink:
PostPosted: Sun Oct 21, 2012 2:47 pm
Yes, your transmission is a 904.
I would purchase this rebuild kit:
Rebuild Kit
and this transmission shift kit:
Shift Kit
I am not aware of any location in Sydney that will have the parts you need in stock. You may wish to contact some of the Australian member on this board and ask them if they know of a supplier of 904 rebuild kits in Sydney.
PostPosted: Sun Oct 21, 2012 3:05 pm
Thanks Reed for the answer.
is this a valve ? which is showing in shifter . what change it will bring?
it means i need more parts other then only kit ? so first let me open the transmission and make some pic for you and then get the advice from all of you.
PostPosted: Sun Nov 11, 2012 9:28 am
Hi Friends,
I have open up the transmission and found Direct Clutch plates are welded to gather to intance heat and the silver piston is melted see the pic below. now good news is that my Aunti is agree to bring parts for me from USA. She is living in Cicago IL. now the plan is that as per suggested by Ceej and Reeds i will buy the A904 Transmission Deluxe Rebuild Kit TF-6 TF6 but i am unable to find the silver Piston bottom of the clutches hold by gient spring see the snap. kindly help me so i can forward the links to my Aunti so she can buy from eBay. Thanks
piston pic
PostPosted: Sun Nov 11, 2012 10:12 am
6 Pack Dart
Part is called piston, you might be best to get the whole assembly.
Richard
