| opening up the plenum on my intake https://slantsix.org/forum/viewtopic.php?t=50176 |
| Author: | DartDude [ Wed Oct 24, 2012 4:56 pm ] |
| Post subject: | opening up the plenum on my intake |
so I just bought a Elctro Welded 2 barrel intake and it has the 2 holes my question is can i cut out the 2 holes to open it up..As I am planing on putting a Holley 2300 on it |
| Author: | DusterIdiot [ Wed Oct 24, 2012 6:01 pm ] |
| Post subject: | Yep... |
You can use a sawzall to make it one big oval....You can also bolt up your Mr.Gasket 1937 and using some blocking and clamps you could even use a holesaw and a drill press to open the holes up to match the 2300/Mr.Gasket adaptor. One thing to note...bigger carb on a small plenum will see quick changes in vaccuum when something changes (i.e. throttle plate position, etc.). Make sure to install a vacc guage to tune by and watch while you drive so you can adjust it for a better driving experience. -D.Idiot |
| Author: | DartDude [ Wed Oct 24, 2012 6:07 pm ] |
I have the Mr. Gasket kit and it has an open plenum |
