It is currently Sun Aug 16, 2026 5:47 am
PostPosted: Wed Oct 24, 2012 4:56 pm
so I just bought a Elctro Welded 2 barrel intake and it has the 2 holes my question is can i cut out the 2 holes to open it up..As I am planing on putting a Holley 2300 on it
1972 Dodge Dart Swinger with a 225 Slant Six
 Post subject: Yep...
PostPosted: Wed Oct 24, 2012 6:01 pm
You can use a sawzall to make it one big oval....You can also bolt up your Mr.Gasket 1937 and using some blocking and clamps you could even use a holesaw and a drill press to open the holes up to match the 2300/Mr.Gasket adaptor.
One thing to note...bigger carb on a small plenum will see quick changes in vaccuum when something changes (i.e. throttle plate position, etc.).
Make sure to install a vacc guage to tune by and watch while you drive so you can adjust it for a better driving experience.
PostPosted: Wed Oct 24, 2012 6:07 pm
I have the Mr. Gasket kit and it has an open plenum
