It is currently Thu Nov 26, 2026 4:10 am
PostPosted: Thu Oct 25, 2012 9:53 am
Ok so my motor mount needs replaced. Already got the replacement bushing. What is the best way to support the engine while replacing this side? Keep in mind that i don't have an engine hoist.
73 Dart custom. Stock.
for now....
PostPosted: Thu Oct 25, 2012 10:07 am
Do you have a floor jack and a concret work surface?
PostPosted: Thu Oct 25, 2012 10:09 am
Place a block of wood on top of a jack under oil pan. Before jacking, loosen and remove nuts holding engine mount and transmission mount than lift engine just enough to remove old engine mount.
You probably will have to lift engine a bit higher to install new mount. Loosely nut upper mount bolts, then lower engine working it around to align lower stud into K member. Have some sort of pry bar handy to persuade new mount into place if needed. Once new mount is in place and engine lowered, correctly torque the nuts; don't forget to retighten transmission mount.
PostPosted: Thu Oct 25, 2012 10:35 am
Yeah I'm working in the driveway with a floor jack. This is my first mount replacement attempt so the tranny mount is on the x member correct?
for now....
PostPosted: Thu Oct 25, 2012 3:27 pm
The mount mounts to a mount............
It's easier to remove both at the same time, split them apart, then re-assemble.
 Post subject: It's a late car guys...
PostPosted: Thu Oct 25, 2012 7:57 pm
1973: It's a spool mount none of the above applies past the 1972 model year....he has to remove the alternator and possibly the radiator overflow bottle to get enough room to work on the through bolt from the front while keeping a wrench on the bolt's nut on the back of the moutn or vise versa. If you get tension on your oil pan per previous instructions you will need to loosen the bolt in the driver's side throughbolt a bit so the engine will 'swivel' when jacked up...
You may also need to jack the car up and get the lower engine block mount bolt from below if your hands aren't skinny enough.
I would also suggest that you jack up the tranny tailshaft a bit and remove the through bolt on the tranny mount for a bit of extra play, given that" your play will then be limited by shifter/column linkage, and the tranny cooler lines.
Make sure to tighten everything back up when done...if the new mount is indeed new, you may need to rock the motor to get the bolt to seat properly in K-member cradle as the geometry from old to new can be off just enough.
Good Luck. Done this quite a few times...remember the process, you will do it again if changing the oil pump in the car as well. :wink:
PostPosted: Wed Nov 28, 2012 7:40 pm
So my transmission mount needs to be changed also. Any tricks to make that one easier?
for now....
 Post subject: Round 2...
PostPosted: Wed Nov 28, 2012 8:19 pm
Chock the rear wheels with a block of wood, and set the e-brake. Jack the front of the car up and put on jack stands under the front subframe near the front door jambs/under the floorpans of the car about even with your tranny.
If you are a bigger guy, jack the back up and put 2 stands under the rear axle... :wink:
Place Jack under tranny tailshaft extension housing and put enough tension on the tranny to lift it slightly...undo the tailshaft mount cross bolt...using ratchet/extension and socket, unthread the two bolts holding the mount to the tranny tailshaft housing...refurbish/replace...replace fasteners in reverse order...
If this is a manual tranny and you are doing some performance driving and/or have a souped up six...apply loctite to the tranny mount bolts before threading and tightening...repeated pounding from hard launches will loosen the bolts and they will fallout somewhere down the road...
Good Luck,
PostPosted: Thu Nov 29, 2012 3:57 am
And... Make sure you have someone working with you throughout the process.
PostPosted: Thu Nov 29, 2012 7:37 am
Using jack stands on a gravel driveway use plywood under the stands. 73 spool mount for the trans can be bought in poly! I have one on my van, one on my 73 cross member in the 72 Duster.
 Post subject: eng bracketry
PostPosted: Mon Jan 07, 2013 10:11 am
Could u send a pic of your eng mt to a mount. I am trying to make the 2 mts that attach to block to accept the motor mts, thanks[/i]
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 14 guests
