| Industrial Engine https://slantsix.org/forum/viewtopic.php?t=50363 |
| Author: | hyper_pak [ Sun Nov 18, 2012 6:32 pm ] |
| Post subject: | Industrial Engine |
I took these pictures a few years ago, I think it was Las Cruces NM. This engine was on the side of the road, looked to have been there 100 years! I got a kick out of it! Enjoy! Ok all you "experts" What Year, CU, ETC! ![]() ![]()
| Author: | DusterIdiot [ Sun Nov 18, 2012 7:36 pm ] |
| Post subject: | Time period |
I've got one of those cartidge oil cans, it came off a 1963 Dodge truck 225, the engine and truck both dated late 1962 manufacture...of all original for a pump engine, it would be in that similar time frame. With the black iron pipe hooked to the air vavle/throttle body it looks like this may bee set to run on natural gas? -D.Idiot |
| Author: | 1969ronnie [ Mon Nov 19, 2012 4:21 am ] |
its also got that great factory engine/trans pulling bracket!!! im surprised nobody has taken it ........... |
| Author: | Mroldfart2u [ Mon Nov 19, 2012 8:48 pm ] |
Quote: its also got that great factory engine/trans pulling bracket!!! im surprised nobody has taken it ...........
Think they would miss their water pump engine.. hard to supply water without it... Yep common practice in these "parts" (west texas, eastern NM, Western Ok, S Ks) to see natural gas as the fuel for irrigation engines... |
| Author: | mcnoople [ Tue Nov 20, 2012 2:36 am ] |
How does the pcv work when there is no airflow past the tube? |
| Author: | GTS225 [ Tue Nov 20, 2012 3:40 am ] |
I wonder where those two lower coolant hoses go to? I can see how it's plumbed....thermo to tank, but it's also going from tank, out through a groundline, then back on another to the water pump? You suppose they're using the engine heat for something? Roger |
| Author: | Slanted Opinion [ Tue Nov 20, 2012 4:40 am ] |
Finally! A slant six that you can change the points on without pulling the distributor... - Mac |
