It is currently Sun Nov 29, 2026 10:08 pm
 Post subject: Industrial Engine
PostPosted: Sun Nov 18, 2012 6:32 pm
I took these pictures a few years ago, I think it was Las Cruces NM. This engine was on the side of the road, looked to have been there 100 years! I got a kick out of it! Enjoy!
Ok all you "experts" What Year, CU, ETC!
 Post subject: Time period
PostPosted: Sun Nov 18, 2012 7:36 pm
I've got one of those cartidge oil cans, it came off a 1963 Dodge truck 225, the engine and truck both dated late 1962 manufacture...of all original for a pump engine, it would be in that similar time frame.
With the black iron pipe hooked to the air vavle/throttle body it looks like this may bee set to run on natural gas?
PostPosted: Mon Nov 19, 2012 4:21 am
its also got that great factory engine/trans pulling bracket!!! im surprised nobody has taken it ...........
PostPosted: Mon Nov 19, 2012 8:48 pm
Think they would miss their water pump engine.. hard to supply water without it...
Yep common practice in these "parts" (west texas, eastern NM, Western Ok, S Ks) to see natural gas as the fuel for irrigation engines...
MRO....
PostPosted: Tue Nov 20, 2012 2:36 am
How does the pcv work when there is no airflow past the tube?
PostPosted: Tue Nov 20, 2012 3:40 am
Car Model: '23 T-bucket
I wonder where those two lower coolant hoses go to? I can see how it's plumbed....thermo to tank, but it's also going from tank, out through a groundline, then back on another to the water pump?
You suppose they're using the engine heat for something?
Roger
PostPosted: Tue Nov 20, 2012 4:40 am
Finally! A slant six that you can change the points on without pulling the distributor...
:D
- Mac
