It is currently Sat Nov 28, 2026 3:13 pm
 Post subject: Six Gun
PostPosted: Mon Nov 19, 2012 3:35 pm
Destroked 300 (272ci) FORD I-6
10.96@121 with 55mm side draft webers
http://imageshack.us/a/img186/5978/picscarstuff007.jpg
11.14@118 with 650DP on HOLMAN/MOODY intake
http://imageshack.us/a/img717/2892/6339527.jpg
PostPosted: Mon Nov 19, 2012 3:43 pm
6 Pack Dart
Very impressive! :shock: :lol:
Richard
PostPosted: Wed Nov 28, 2012 5:59 am
Very impressive indeed...tell us more about your combination. Weight, gears,trans etc. What rpm do you launch at?
Any inline stick shift is inspiring in my books, nice car!
Derek
70 Duster 238'', four speed ,3:91's, 500 Elde, Hookers
68 Dart 4 dr 225, completely original
PostPosted: Thu Nov 29, 2012 9:21 am
Engine: Destroked 300(272 CID)
Pistons: Wiseco .060 over
Rods: 6.980" Fowler aluminum
Crank: Factory steel, destroked to 3.500"
Cam: Racer Brown .700 lift
Ignition: Vertex Magneto
Induction: (3) 55MM Weber side drafts on a Clifford intake
Exhaust: Home made 6 into 1, 1-3/4" primary tube
Best ET: 10.96@120
HP: about 420
Weight: 2800 lbs.
Trans: Jerico 4 speed
Rear end: 9" Ford 5.43 gear
I launch @ 7000 shift @ 7000 go threw @ 7300!!
PostPosted: Thu Nov 29, 2012 11:31 am
Schweeeet! :D
PostPosted: Sun Dec 02, 2012 4:43 pm
Wondering why you destroked it.
PostPosted: Mon Dec 03, 2012 10:48 am
SOME VIDEO
http://img26.imageshack.us/img26/9264/carstuffii008.mp4
http://img51.imageshack.us/img51/1264/c ... iii006.mp4
http://img830.imageshack.us/img830/9554 ... iii008.mp4
PostPosted: Mon Dec 03, 2012 10:59 am
Exner Geek:
I DESTROKED it because of (((VIBRATION))) problems when I went to a stick..
With the stock stroke it would shake the flywheel bolt out...
PostPosted: Tue Dec 04, 2012 5:46 am
WOW.... Impressive, and the sound of a stick car being rowed thru the gears is great....
MRO....
