It is currently Fri Nov 27, 2026 3:09 am
 Post subject: Copper head gasket
PostPosted: Sun Nov 25, 2012 6:47 pm
Has anyone been able to reuse the copper gasket on the aluminum block engine and get it to reseal. What head gasket sealer was used?
PostPosted: Sun Nov 25, 2012 8:02 pm
Car Model: 64 Valiant
Copper head gaskets don't really work good unless the block or heads are o-ringed or machined for receiver grooves. Since the aluminum blocks have a relatively small diameter cylinder barrel, its going to be hard to o-ring one of them to use a copper gasket correctly or successfully.
PostPosted: Mon Nov 26, 2012 5:39 am
He is talking about the OEM copper laminate gasket for the alum engine. I don't know. Doc might.
PostPosted: Mon Nov 26, 2012 8:33 am
I would doubt that you would be able to reuse one of those gaskets, especially if the engine has been heat cycled. (run)
For fun, let's say you get a rebuilt Alm block SL6 and pull the head-off to inspect it... and the special head gasket comes-off "clean", with no damage.
Upon inspection, all the surfaces are clean and freashly cut. (head & block) In this situation... I would likely take a chance and try to reuse the "never run but crushed" head gasket. I would carefully clean everything, spray the gasket with Hylomar sealer and re-install.
I would do a retorque after the first heat cycle and tighten 5 ftlbs more then the call-out.
I would also be looking to purchase a spare head gasket to have available... "just in case..."
PostPosted: Mon Nov 26, 2012 3:46 pm
Thanks everyone for your input. Here is the rest of the story.The situation--Retired --maximum time,minimum money. The scenario-- My 62 valiant with a alum block still runs well but now has some blowby and the compression is down betwwen 100 and 106 psi. I have had an extra alum engine for some time now that appears to be in great shape, no corrison at the top of the cylinders or in the water jasket. (Thanks Vdart) The only problems I found were the rings were carboned up and froze in the lands plus two exh. valve were burnt.
I have cut the ridge down ,honed the cylinder walls added new standard rings and put it back together except for the head. I have a 73 head that is good and flat and will use it with the old head gasket to see if it will seal.
Out side of me being cheap the other reason I am going to try this is the machine shop I have used in the past it skeptical of boring it because of cylinder wall flex?? Any ideas appreciated. Thanks
PostPosted: Mon Nov 26, 2012 4:14 pm
...I have a 73 head that is good and flat and will use it with the old head gasket to see if it will seal.
This is not going to work, for 2 reasons.
1) The special Alm. Block SL6 head gasket will not be in one piece when it comes-off a high mileage used engine.
2) It is unlikely that you will have complete gasket compression and cylinder bore, end coverage, if you do not have the correct head for the Aluminum engine.
I just "fitted" a non aluminum block SL6 head to an aluminum engine I am rebuilding. I mounted the empty engine block onto a engine stand, installed a used head onto it, (using an old gasket & 2 head bolts) flipped the engine over and looked down each empty bore with a bright light.
The first head I tried was shifted right about .060
The next head I tried was shift right and rearward.
The third head was forward about .030 and a bit to the right in front but well centered in back so I used that head & some off-set dowel pins to get all the chambers centered over the bores.
Bottom lime, it took 3 different heads, 2 hours of work and a sore back, to get the needed head gasket contact and "crush" area, that you absolutly need, in order to seal the head gasket on one of these engines.
PostPosted: Mon Nov 26, 2012 6:05 pm
Thanks Doc, Looks like I am back to square one on this project
PostPosted: Tue Nov 27, 2012 8:30 am
Is the oil pan installed yet?
If not, I would take-out pistons # 1 & 6, then do the head "fit check" as discribed.
If the pan is on, then get a head gasket and some additional 1/4 dowel pins, then use the gasket as a "template", to check the relationship between the block and the head chambers.
The main area to look at is next to the valves, where the factory cut-away head chamber wall, to unshroud the valves. Many non alm. block SL6 heads have large cuts in this area that prevents "crush" between the block's iron bore liner and the head.
Take a caliper to the head chambers and measur the combustion chambers, front to back. on the cuts. If that distance is a lot larger then your bore size, (3.400) start checking different heads.
PostPosted: Wed Nov 28, 2012 5:52 pm
In case you can't locate a head gasket for your aluminum block, try AMS Obsolete (http://www.mmpar.com/StoreVBVS2011/default.aspx). I bought one (NOS) from them recently. They also have a lot of other hard to find early A parts.
PostPosted: Mon Jul 01, 2013 3:04 pm
First of all let me say that Doug was right. I was unable to get the used gasket to seal on the alum. block, I am getting some air bubbling in the radiator. Now the good part this engine starts and idles well. Now the bad part-the only thing new on this engine are the plugs ,points, condenser,oil and filter. the compression readings are Cold #1-75,#2-80,#3-70.#4-
70, #5-105,#6 86, after oil added to cylinders. 140,140,125,120, 150, 140.
after one hot cycle 115,110,96,100,125, 120. I can not get #5 cylinder to fire,I have a good spark to it and the new plug is wet with fuel. Changed plugs and wire around with no results. Also did a leak down test with 90# of air to try and find out where the head gasket is leaking-No luck. Any ideas appreciated. Thanks
PostPosted: Mon Jul 01, 2013 4:22 pm
You run the risk of damaging this engine by letting coolant into the bores.
Chalk one up to "learning experence" and pull the engine / head ASAP and dry the cylinders out, then oil them well.
If you can not dis-assemble this engine quickly... drain all the coolant, pull all the plugs and crank the engine to expel the coolant, then spray oil into the cylinders & crank some more.
Do not attempt to start the engine again, unless you pull the plugs or it may "hydraulic" and break / bend parts. (Coolant does not compress)
Just a little mosture sitting in the bores will cause corrosion... pitting the cylinder wall(s), sticking the rings, corroding the pistons, etc.
PostPosted: Mon Jul 01, 2013 5:30 pm
Doug thanks for the quick reply. Drained the water, checked the oil pan for water and found none. Pulled the plugs and added oil and wd 40 turned over engine with starter. Note -do not rotate engine will oil in cylinders without putting masting tape over drool tube ports unless you like
oil mist on the garage floor.
This engine was the smoothest running 5 cylinder I know of.
Did run another compression ck. after oiling down cylinders #5 was 165# the rest were in the 112 to 120 range?
Late note -did not see any water or mist when first rotating engine after
pulling plugs
Users browsing this forum: No registered users and 30 guests
