It is currently Fri Nov 13, 2026 9:55 pm
PostPosted: Fri Nov 30, 2012 3:33 pm
I bought a new ring and pinion advertised to fit a 7 1/4.
After removing the wax I found the ratio stamped at 3.21 not 3.23.
Now I'm thinking the advertisement was wrong & it's for an 8 1/4.
The ring gear has 2352938 part number stamped on it.
Can anyone confirm it's true identity before I tear down my 7 1/4 rear & it doesn't fit.
How do you measure a ring gear to check for 7 1/4?.....to the OD? to the center of the teeth?
Thanks.........Don
PostPosted: Fri Nov 30, 2012 4:08 pm
Measure across the OD of the ring gear...
 Post subject: Grime...
PostPosted: Fri Nov 30, 2012 5:44 pm
2852938 is for an 8 1/4" 3.21 ring gear
2352938 is an early part number almost early 60's-ish...is there some grime making the 285 a 235 maybe?
Time to break out the tape measure as Doc says.
PostPosted: Sat Dec 01, 2012 2:29 am
Extreme O.D. of gear.....right out to tip of teeth...measures 8 5/8.
After closer scrutiny & more wax peeling the part number is a 2852938.
The pinion might give a hint if the ring gear doesn't with numbers:
35079 5 3 21 with a bearing stem dia of 1 1/2 dia. (definitely not 1 3/8!)
It has the MOPAR pentastar stamped in it
So based on the OD measurement I better not tear into my 7 1/4 yet!
My 65 parts manual shows numbers like 2467 326 for a Dart 3.23 pinion/gear set with or without sure grip......I wonder why they don't show individual ring gear numbers for the Dart/Valiant?
That same manual also shows the 65 B & C bodies to have an 8 3/4 with 3.23 ring gear 2070 816
Consequently based on the OD & part number this could be a later 8 1/4 or 8 3/4 ring gear?
Thanks for the responses........Don
 Post subject: 8 1/4"?
PostPosted: Sat Dec 01, 2012 9:11 am
According to the 1973 Parts Manual the stem size on 8 1/4" are 1 5/8" and 8 3/4" are 1 7/8"
Pinion # for a 3.21 is:3507915 or 3723044
So it looks like you have an OEM 3.21 set for an 8 1/4"
PostPosted: Sat Dec 01, 2012 11:13 am
Summary: Based on the part numbers & ratio on both ring gear & pinion and your research it looks like a sure fire 3.21 ratio 8 1/4 with the smaller pinion stem diameter.
Thanks to your help I now know what to do....and it sure means for me....don't touch that 7 1/4 rear yet.
I altered the title so if someone is researching the same part numbers the'll have your research
Thanks..Don
