It is currently Thu May 21, 2026 8:24 pm
 Post subject: relays
PostPosted: Sun Dec 23, 2012 11:16 am
First i would like to say i have always adored slant six....my last car was a straight six rambler but now im proud to own a 78 volare wagon.I was thinking of adding relays to the hei i put in..blower motor...and headlights as well as beefing up the headlight wiring.How does this sound?
Love inline sixes
78 AMC Concord 258
PostPosted: Sun Dec 23, 2012 12:14 pm
You sure are not going to hurt anything, and maybe even help out the 30+ year old wiring and switches..
MRO....
 Post subject: Re: relays
PostPosted: Sun Dec 23, 2012 12:31 pm
Sounds like very good and often recommended upgrades!
PostPosted: Sun Dec 23, 2012 1:04 pm
I did the relay thing when I added HEI and also spliced in a "kill switch" to deenergize said relay. Might come in handy while working underhood and need the engine shut down right now should an emergency arise.
PostPosted: Sun Dec 23, 2012 7:38 pm
Relays, and also upgraded wires - if necessary - is a very good idea, check here for the voltage loss in the wiring harness in my Aspen.
Gm Hei Module Conversion Troubles
As long as you're under the hood, do yourself a favour, and double check all your ground connections and fusible links.
Happy Holidays.
Olaf
Aspenized
PostPosted: Mon Dec 24, 2012 12:48 pm
Ok so i added a nice bosch 30amp relay to the heater much better perfornance..then put one on my hei..then put a 60 amp fusible link behind the alt...how does this sound?
Love inline sixes
78 AMC Concord 258
PostPosted: Wed Dec 26, 2012 1:14 pm
All sounds good, Slanty, and welcome to the forum.
ATB
BC
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
