It is currently Sat May 23, 2026 10:16 pm
PostPosted: Sun Jan 13, 2013 7:33 am
The 65 Dart FSM uses a testor (assume with variable resistance) to evaluate the sender & guage.....there is no mention in the specs or writeup of the OEM stock sender desired resistance range (ie 10 to 70 ohm or whatever).
Does anyone have these figures?
My problem is the guage reads over full when completely filled & empty when it's only down 9 gallons......I try not to fill my tank to avoid spillage when full......with the current guage readout discrepancy I'm reloading every 7 gallons which is every 3 days/200 miles.
PostPosted: Sun Jan 13, 2013 7:50 pm
I'd also be greatly interested in this as well for a 76 Aspen if someone has the info. Buying gauges for custom dash cluster, wanna make sure I get the correct resistance.
Thanks,
Aspen76
76 Dodge Aspen
225 Super Six w/ Dutra True Dual Exhaust
http://i1245.photobucket.com/albums/gg5 ... AG0095.jpg
http://www.youtube.com/user/BZuko1?feature=guide
 Post subject: No but...
PostPosted: Sun Jan 13, 2013 8:48 pm
I don't have the stock range, but the after market Spectre version I got is 10-85 ohms...It works OK with the stock dash gauge.
-D.idiot
PostPosted: Mon Jan 14, 2013 4:59 pm
I believe the stock range is something like 10-73.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
