| Tire/Wheel thoughts https://slantsix.org/forum/viewtopic.php?t=50935 |
| Author: | carrigan #3 [ Sat Jan 26, 2013 2:14 pm ] |
| Post subject: | Tire/Wheel thoughts |
I'm doing a disc swap and front end rebuild, which swaps me to BBP and requires new rims and tires. Here's what I'm looking at: 225/60R15 on 15x7 rims Here's my question: What kind of backspacing might this require ('71 Dart Swinger with '74 disc parts up front, 7.25 with 10" drums out back)? And with that said, what length studs should I look at installing (the current studs extend 1" beyond the drum/rotor hub)? Thanks for the help! |
| Author: | DusterIdiot [ Sat Jan 26, 2013 9:18 pm ] |
| Post subject: | Yep... |
Stock studs should be fine if the backspacing is stock and no adaptors were used. Backspacing is about 4.25" to 4.5" depending on style of rim and application/rim width. -D.Idiot |
| Author: | carrigan #3 [ Sun Jan 27, 2013 7:43 am ] |
Thanks D.I. I'll test fit everything with stock studs and go from there. |
