It is currently Thu May 21, 2026 8:51 am
PostPosted: Fri Feb 01, 2013 5:17 pm
How does one tell the difference between a '60-'62 slant head and one from '63 to '74?
 Post subject: Casting Numbers
PostPosted: Fri Feb 01, 2013 5:29 pm
Check the casting number under the valve cover.
There is a listing in the articles tab "Table listing Heads, Crank & Block variations" That has most of the common numbers.
PostPosted: Mon Feb 04, 2013 8:29 pm
aren´t they equals anyway?
Mopar or no Car!
PostPosted: Mon Feb 04, 2013 8:41 pm
Other than the improved chamber design change in '68 I dunno :?:
EDIT: Oh, there is the hardened exh seats in '72+.
1966 Coronet Deluxe
PostPosted: Mon Feb 04, 2013 10:30 pm
Combustion chamber redesign, drool tubes vs. peanut plugs, rear rocker shaft bolt change, air injection tubes, square vs. rounded valve cover, extra ports in the water jacket for coolant operated vacuum switches and sensors, different sized coolant temp sending units. Some of the various differences between 1960 and 1987.
Users browsing this forum: No registered users and 23 guests
