It is currently Fri May 15, 2026 6:29 am
 Post subject: Holley 2280 parts
PostPosted: Mon Feb 11, 2013 6:20 pm
I need the air cleaner adapter for my Holley 2280 ..you know its the little deal with the aircleaner stud atteched to it !
1972 Dodge Dart Swinger with a 225 Slant Six
PostPosted: Mon Feb 11, 2013 7:48 pm
You can buy a small 3" air cleaner from local parts store it should have the carb. Attachment ring and stud. Then toss the 3" cleaner and attach your air cleaner to it.
Here's a pic of mine, with a 10" mr gasket air cleaner.
http://s1270.photobucket.com/albums/jj602/Szabo99/
74 Dart Swinger, supersixed.
 Post subject: Uh no...
PostPosted: Mon Feb 11, 2013 9:12 pm
He's looking for the "bail" which is the wire clip that attaches to the carb throat and holds the 'stud' for the air cleaner lid to wing nut to...
Junkyard part.
Good Hunting,
PostPosted: Thu Feb 14, 2013 6:16 pm
Ya I know I had a hard time finding one too... the small 3" air cleaner im talking about came with the stud assembly for the air cleaner that mounts to the horn. It mounts around the horn and is secured by a small screw. The stud t
Where the wing nut goes is part of the assembly, you can then mount whatever air cleaner you want to it as long as it fits under the hood.
Just a suggestion.
