It is currently Mon May 25, 2026 3:24 am
 Post subject: Engine Calculations
PostPosted: Thu Feb 14, 2013 5:18 pm
I am putting together an excel spreadsheet that can be used to calculate engine dynamics. So far I have Engine Dsiplacement, Engine size in CC, I have combustion chamber total and static compression ratio. I am still looking for a calulcation for dynamic compression ratio. Any other calculations that would be helpful? I am hoping to be able to create a graph for hp/torque ratings based on rpm.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
 Post subject: $40?
PostPosted: Thu Feb 14, 2013 9:26 pm
For about $39.99 you could just get a copy of Dyno 2000 and have it do everything (except the DCR, you can download that one off the web).
Luckily there are a few flow bench results on the board you can use to 'dial in' the flow map on the program.
