| camshaft sprocket install? https://slantsix.org/forum/viewtopic.php?t=51271 |
| Author: | slant6 [ Fri Mar 01, 2013 12:09 pm ] |
| Post subject: | camshaft sprocket install? |
225 slant 6 eng.seems like there should be a spacer between my sprocket gear and block I haven't torqued my nut yet but want to make sure first, advise thanks, Dana |
| Author: | Reed [ Fri Mar 01, 2013 12:21 pm ] |
Nope, no spacer. There is a washer between the stock hold-down bolt and the cam gear, though. |
| Author: | slant6 [ Fri Mar 01, 2013 12:43 pm ] |
Yes, that I'm o.k. Thanks for quick response, more que. Will be coming. |
| Author: | emsvitil [ Fri Mar 01, 2013 7:12 pm ] |
Is the same thing happening to you that's in this thread: http://www.slantsix.org/forum/viewtopic.php?t=51128 |
| Author: | 69a100 [ Sat Mar 02, 2013 7:41 am ] |
| Post subject: | Re: camshaft sprocket install? |
Quote: I haven't torqued my nut yet
Now that's funny! |
