It is currently Tue Oct 13, 2026 2:38 am
 Post subject: SL6 Engine swap
PostPosted: Sun Mar 03, 2013 12:31 pm
Hello , i have a 1965 Dodge A-100 van with a sl6 170 3 on the tree , motor is tired , looking at a 1976 sl6 225 fresh rebuild wondering if i will have any major issues with this swap or will it bolt right up ??
thanks in advance vm2 j
 Post subject: Yes and no...
PostPosted: Sun Mar 03, 2013 3:34 pm
It will bolt right up but you will need a late flywheel for the 1976 engine, or have the cank hole in your flywheel enlarged for the late crank (or maybe you can find someone on the board to do a trade for a late flywheel if they need an early one...
If junkyarding, you are looking for one from a 1968-1987 slant six (cast crank truck flywheels are a little heavier if you need the weight).
Users browsing this forum: Bing [Bot], Google [Bot] and 2 guests
