| SL6 Engine swap https://slantsix.org/forum/viewtopic.php?t=51293 |
| Author: | vanman#2 [ Sun Mar 03, 2013 12:31 pm ] |
| Post subject: | SL6 Engine swap |
Hello , i have a 1965 Dodge A-100 van with a sl6 170 3 on the tree , motor is tired , looking at a 1976 sl6 225 fresh rebuild wondering if i will have any major issues with this swap or will it bolt right up ?? thanks in advance vm2 j |
| Author: | DusterIdiot [ Sun Mar 03, 2013 3:34 pm ] |
| Post subject: | Yes and no... |
It will bolt right up but you will need a late flywheel for the 1976 engine, or have the cank hole in your flywheel enlarged for the late crank (or maybe you can find someone on the board to do a trade for a late flywheel if they need an early one... If junkyarding, you are looking for one from a 1968-1987 slant six (cast crank truck flywheels are a little heavier if you need the weight). -D.Idiot |
