It is currently Sat Nov 14, 2026 5:37 am
PostPosted: Sun Mar 24, 2013 6:14 am
I've been looking for an original Chrysler replacement part for quite some time without success for the sealed ball bearing assembly.
NAPA, AutoZone, Etc. lists a RWF34R sealed bearing unit & EBAY has a bunch made by different manufacturers.
Problem is that as many Ebay auctions say it doesn't fit as auctions that says it does fit which raises the point that maybe this fits the later model 7 1/4 axles & NAPA etc. may not have it right.
The bearing specs listed are OD 2.6772 & ID 1.3386
As many sellers list the width as .944 as list it at 1.2849
This gives me the feeling that many sellers do not have a firm grasp of the application or the bearing specs.
Besides I have a concern over the bearing quality.
Can anyone verify the 65 bearing dimensions?...
PostPosted: Thu Apr 11, 2013 3:55 pm
What I measured for rear axle bearing after disassembly:
O.D. 2.677
I.D. 1.339
Width .828
Rear Axle Bearing Chrysler part number 2421 349 seems to be the same as RWF-34-R
