It is currently Thu Jun 11, 2026 12:46 am
 Post subject: regulator epoxy goo
PostPosted: Thu Nov 29, 2012 8:15 am
Car Model: 75valiant custom
when i bought my valiant, there was some type of voltage regulator mounted on the left side fender that had fried. i bought a new one and it runs and charges fine.
my question is, what can i use to remove the epoxy goo that dribbled all down my inner fender? that stuff is ON there, and it's nasty looking. i've got a clean car, only 63,000 one owner miles.
PostPosted: Thu Nov 29, 2012 8:24 am
Car Model: 1964 Valiant V200
I can't think of anything that won't harm the paint. Acetone or MEK will remove it but might damage the paint. Maybe try cleaning solvent/Naptha/Mineral Spirits?
PostPosted: Thu Nov 29, 2012 9:25 am
Try WD40... and a plastic dish scrubber. (NOT a 3M pad type)
MRO....
PostPosted: Fri Apr 26, 2013 6:31 am
decided just for fun to hit it with the old power washer. i was initially impressed, but it seemed that the water just kind of "beat it up." later, i was leaning under the hood when much to my surprise my hand was glued to the inner fender. seems i have brought it back to life.
i noticed that when i first posted this thread, the charging system was working fine. now it's not. the only thing i can think of is maybe i got something wet. in any case, i've still got work left to do.
PostPosted: Sat Apr 27, 2013 2:36 pm
wonderful chinese- made borg warner voltage regulator was stuck open. got a new regulator and the rebuilt alternator charges like crazy.
PostPosted: Sat Apr 27, 2013 4:17 pm
Did you ever get the goo off your hand?
and the car?
I use lacquer thinner let it dry well, then polish it with some wax.
The product "Goof Off" works well too...
PostPosted: Mon Apr 29, 2013 12:05 pm
hey, i'll try that! thanks!
