It is currently Mon Nov 16, 2026 3:44 pm
PostPosted: Sun Apr 28, 2013 5:37 am
programs are written and the first run of adapter plates are finished.
There are two unique adaper plates, one to fit a Lakewood housing to a slant six and one to fit a Quicktime housing to a slant six.
Initially we expected the LW and QT partterns to be simular and overlap, they ended up being two unique adapters.
Either adapter will get you the ability to run a 130 tooth mopar flywheel with your slant six , that opens the door to an array of clutch packages.
the plan is to have the kit include all unique fastners, a choice of plate material, steel or aluminum and either plain or powder coated finish.
Pricing is being firmed up. It is planned that the adapters will be distributed through the Mooresville IN office of Wayne Enterprises
http://www.flickr.com/photos/13718356@N ... 354369907/
the photos show the Lakewood and QT adapters side by side,
as these bell housing put the starter in the low position, I included a photo with a standard slant manual bell on top of the QT adapter to give one a perspective of the low starter position. The low starter position is aligned with, and inside of the clutch fork.
There are also photos that show that if the stock A shaped side bracket is rotated 180 degrees, it will attach cleanly to the vacant high mount starter location.
