It is currently Mon May 18, 2026 6:42 am
 Post subject: 1975 swinger brakes
PostPosted: Fri Apr 26, 2013 11:13 am
my brakes are not holding pressure and my master cylinder has started leaking fluid very badly. seems to be close to where it mounts to the fire wall. i dont see fluids coming out anywhere else. is it possible to clean and repair cylinder, or is that just a waste of time?
PostPosted: Fri Apr 26, 2013 11:20 am
It is cheaper and faster to replace the master cylinder. Get one from NAPA Auto Parts if possible, or some one that will guaranty their products.
It would be good to flush all new fluid through the brake cylinders by bleeding each one to get rid of the contaminated fluid.
PostPosted: Fri Apr 26, 2013 11:30 am
thank you again. my fluid is very dirty and i suspected that i should run fresh fluid till it runs clean. i will check into napa so far autozone has been steady the best deals, but would honestly rather buy somewhere else.
 Post subject: job done
PostPosted: Fri May 03, 2013 8:15 am
master cylinder in, brakes bled, pressure good.
PostPosted: Fri May 03, 2013 12:16 pm
Cool! Glad to hear that did that helped.
