It is currently Fri Jun 12, 2026 10:36 pm
 Post subject: Ignition problems
PostPosted: Tue May 07, 2013 8:07 am
I just rebuilt my 225 slant but it won't start, it has fuel but the spark is very weak. Anyone who have pictures on the disturberator and how it should fit?
I bought my 65 Valiant last summer and it's my first car so a little help wouldn't be bad :wink:
Thanks!
PostPosted: Tue May 07, 2013 9:47 am
Welcome to the Board! I am guessing that you are looking for the firing order. There is a diagram on this page that shows how the wires are connected between the distributor and the plugs.
http://www.crankshaftcoalition.com/wiki ... _order.jpg
It is also possible that you have inserted the distributor into the engine with the distributor out of timing sequence. Checking that involves getting the #1 cylinder to top dead center on its compression stroke, then checking to see that the rotor is aligned with the #1 post on the distributor cap. Figuring out which stroke is the compression stroke is done by removing the valve cover.
Finally, there's a chance that you've got everything right and you have a weak component in the ignition system. Is the spark strong enough to fire across a spark plug?
- Mac
[/url]
PostPosted: Wed May 08, 2013 3:05 am
- Mac
[/url]
Thanks for the quick answer but the igniton timing marks are gone on the timing chain cover, is there any pics on the marks who could help me?
Valiant -65
PostPosted: Wed May 08, 2013 3:15 am
You can still check the timing to be sure you got the distributor in correctly.
Read through this post:
http://www.slantsix.org/forum/viewtopic ... 2add07eaca
- Mac
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
