It is currently Fri Nov 20, 2026 9:01 pm
PostPosted: Sat May 25, 2013 8:39 pm
Hi Everyone,
Does anyone have an extra return hose fitting out there? The part has the Mopar part number: D-1733734 . This is where the low pressure hose fits into the top of the power steering gearbox. I'm using the fitting that comes off of a 1962 or latter model, but would put the original back on if anyone out there has it. It's also called an aluminum return port. Or does anyone make these now as a replacement part? Please let me know if the part is still out there, thanks, Jerry7777
PostPosted: Thu May 30, 2013 9:17 am
Hi Everyone,
Believe it or not, I found the replacement part on Ebay. Never thought that it would be that easy. Since my power steering unit is working perfectly, I'll just save the part in case I need it somewhere down the road. I've got Four A-Bodies, all with the immortal Slant Six Engine. What a lucky guy I am, Jerry7777.
