It is currently Mon Nov 30, 2026 2:26 am
 Post subject: Easy Click System
PostPosted: Sun May 26, 2013 5:16 am
Here is a simple little [url=http://www.alfadirect.com/]gizmo[/url] I discovered when looking up Dan Woods of “Chop Cut Rebuildâ€￾. One of the few North American distributors is [url=http://www.classicindustries.com] here [/url], search for part # EC100201.
PostPosted: Sun May 26, 2013 10:05 am
Nice!
Just need to know the correct part numbers......
PostPosted: Sun May 26, 2013 5:31 pm
Ted, I clicked on the "Add to Cart" button and got this:
EC100201 EASY CLCK SELF TGHTNG BAT CLMP $24.99 pr
Then I emptied the cart, and bailed, UNimpressed! I've always hated those clamps that you bolt the cables onto. I believe with the insulation cut back, the conductors are wide open for corrosion to start. I've seen that green creepin' crud 4-5 inches up the cable.
I much prefer these . I like overkill, it beats the snot out of NO kill.
Of course YMMV!
BC
 Post subject: X2
PostPosted: Sun May 26, 2013 7:08 pm
I've used them and actually had a wire fall out of the clamp... :shock:
Not a good thing when it was the red wire for the main starter lead.
PostPosted: Mon May 27, 2013 2:17 am
Put a lug on the end of the cable, then bolt the cable to the battery terminal with the bolts rather than clamp the wire with the bolts.........
