It is currently Sat May 23, 2026 10:07 am
PostPosted: Wed May 29, 2013 4:42 am
Was wondering if anyone else think's the K frame should be removed for painting/ Rebuilding the front end?. If so how do you work out the tourqe bars?
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Wed May 29, 2013 5:38 am
You don't need to remove the K frame when you rebuild the front suspension.
There is a special "torsion bar removal tool" that clamps onto the torsion bar without scratching it. You then hit the tool with a hammer to drive the torsion bars out.
There are other more "shade tree" ways to remove them, but that's the "right" way. :wink:
PostPosted: Wed May 29, 2013 6:22 am
Rob do you have to get the torsion bars out to drop out the lower arms?
 Post subject: Yes
PostPosted: Wed May 29, 2013 7:11 am
They have to walk back at least 8" to get the LCA Bushing studs to clear the K-member they are bolted through.
PostPosted: Wed May 29, 2013 7:42 am
So you have to unbolt that and knock the torsion bar back till your cleared?
 Post subject: Yep...
PostPosted: Wed May 29, 2013 7:46 am
http://www.slantsix.org/forum/viewtopic ... ar+removal
These should shed some light...
PostPosted: Wed May 29, 2013 8:09 am
Thank you sir! :D
