It is currently Sat Nov 28, 2026 11:45 pm
PostPosted: Mon Jun 17, 2013 6:13 pm
Hi All,
The engine mounts went out in my 64 valiant convertible. I ordered from Rockauto.com, who sources from Anchor. Parts # 2234 and 2235 are listed for /6, but apparently they're different for convertibles. Anyone know what is up with this? It looks like the 64 motor mount for a 273 will work for the one that doesn't. I need to get my car on the road ASAP, any help is appreciated. Thanks!
PostPosted: Mon Jun 17, 2013 7:56 pm
Site Admin
First of all, I don't know. I hadn't heard there was a difference between the convertible and any other 63-66 A-Body mount.
Bruce Pine may know. He has a nice Convertible that he may have purchased mounts for. There are a lot of early A convertible owners on the site. Give them a chance to read this.
CJ
PostPosted: Mon Jun 17, 2013 8:33 pm
Car Model: 62 Lancer, 63 D100
I have the same motor mounts in all '62-'66 A-Body 6 cyl. Darts and Valiants.
Including convertibles.
Rock Auto online lists only one left and one right engine mount for 1964 Valiant 6 cyl. They look like the proper mounts.
V8 mounts will not fit.
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Mon Jun 17, 2013 8:39 pm
Site Admin
If you go to the home page, then click on parts list, a search engine will pop up.
Enter one word in each box. Motor in one box, and mount in another.
(If you put two words in one box it will only return EXACTLY that search, which will probably be empty.)
Give it a try. There are mounts listed for your car.
Another option is to go to www.Polybushings.com . Johnny Spiva sells poly mounts for the 62-66 A-body cars. You will probably want a soft durometer mount. They are more expensive than the Asian Yak Poo ones, but they are "Captured" mounts. They will likely never need replacing. Johnny built them for our group, along with Spool mounts for later cars.
:D
CJ
PostPosted: Mon Jun 17, 2013 9:18 pm
Another option is to go to www.Polybushings.com . Johnny Spiva sells poly mounts for the 63-66 A-body cars. You will probably want a soft durometer mount. They are more expensive than the Asian Yak Poo ones, but they are "Captured" mounts. They will likely never need replacing. Johnny built them for our group, along with Spool mounts for later cars.
:D
CJ
I will chime in here. I just bought a set of these for my 63 Dart wagon project, and I must say, though I've not yet installed them in the car, they certainly look like they'll do a great job. Interested to see how well they hold up, but it was the video that Fopar posted about these that made me want to order a set:
http://s77.photobucket.com/user/rbjerkl ... t.mp4.html
Here's my engine mount thread with some good comments:
http://slantsix.org/forum/viewtopic.php ... gine+mount
PostPosted: Mon Jun 17, 2013 9:20 pm
Thanks guys. I will try polybushings. The mount for my passenger side from rockauto is incorrect; it's got two studs down and one up. My valiant is one stud down and one facing up. It looks like the 273 mount from rock auto.
Now I'm wondering if someone switched out a 273 for a 225. Unlikely I guess, but it's curious. Guess I can check via vin. I'll also look more closely -- perhaps someone used the wrong mount with only one stud but there are two holes. Didn't look like it thought...
 Post subject: Juyst to clarify...
PostPosted: Mon Jun 17, 2013 9:23 pm
Just in case you didn't know, factory A-body mounts were plain "sandwiches of rubber between the mount plates and studs. in the 1973 Model year Mopar moved the motor mounts to captured "spool mounts" on all vehicles except Trucks and Vans ( and the 1973-1974 E-body...)... Mopar figured that if the rubber sandwich failed that the mount would not keep the engine in place and things would not work out too well. The later truck mounts have a set of interlocking tabs that will catch if the rubber mount fails. The V-8 crowd latched onto this early on since the V-8 mounts between the trucks and most cars with sandwich mounts were compatible. The polybushings are so far the best available mounts for durability with this safety feature for your generation A-body.
:wink:
PostPosted: Mon Jun 17, 2013 9:31 pm
Site Admin
Just noticed that I typo'd. The mounts are for '62-'66 A-body cars.
oops. :oops:
CJ
PostPosted: Tue Jun 18, 2013 3:40 am
Poly mounts are better. However Autozone has the correct mounts. EM-2303 and EM-2304
PostPosted: Tue Jun 18, 2013 10:28 am
So, I'm not crazy -- there is only one mount hole, so the motor mount with two downward facing studs is incorrect. Charlie_S, the parts you sent look like the correct ones, but autozone.com is telling me they won't work for my application. Are these for 273? Don't take it personally, but are you sure they'll fit?
And as an aside, for those of us who know the difference between a motor and an engine, why the hell aren't they engine mounts? Is the American auto industry a fan of alliteration?
 Post subject: Uhhh..not exactly...
PostPosted: Tue Jun 18, 2013 10:47 am
They are using a database compiled by programmers, not experienced hands on guys like Charlie. I have caught several A-body "issues" with Autozone and other chain's databases (in fact Autozone's data base says that 1967-1968 Valiants can come with 9" or 10" drum brakes, but in 1969 the only come with 10" drum brakes...which is a big *Whoops*-meaning the end user will need to tell the counter jockey that they have a 1968 to get the correct 9" front brake pads and drums...).
This is why this board is a great resource, you will have to be your own parts advocate as many places start moving away from providing parts for cars that are "fewer" in number on the road. If you want to fast service, just walk in with the part numbers and see if the kid behind the counter can't believe you know what you are looking at (most of the parts stores here know me on site now and know I will be in and out quickly because I know what is needed).
FYI.
PostPosted: Tue Jun 18, 2013 12:07 pm
Ordered the autozone ones... they'll be here in a day or two and figure if they're not right either I can just return for a restock fee. My valiant is my only car right now, and I need that thing back on the road! Thanks guys for all of your help!
PostPosted: Wed Jun 19, 2013 7:28 am
Reread your previous post. The part numbers I gave you are correct, for a 63-66 "A" body with a slant six. I have them on the shelf in the boxes. The pasenger side mount does have two studs, that bolt to the engine bracket, and one stud that goes into a slot in the "K" member. The driver side has one stud that goes into the engine bracket, and one stud that goes into the "K" member. If your pasenger side engine bracket does not have two holes for the mount, that is your problem. Wrong bracket.
PostPosted: Wed Jun 19, 2013 7:36 am
I can confirm Charlie's diagnosis. I just put my motor back in and the passenger side has 2 studs that go into the mount and 1 into the frame. Also the flat side should be oriented towards the outside. The drivers side has 1 stud on each side that are offset from each other. This is the a picture I had with the motor mount. I have it installed upside down oops but you can clearly see what it should look like.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Wed Jun 19, 2013 7:46 am
Also, I went to the autozone web site. They do not list a motor mount for the 64 Valiant, but do list for the 64 Dart. All slant six motor mounts are the same for 64-66 Valiant, dart, barracuda, with a slant six engine. The parts listings for these years/modles/engines are messed up. If you can't find the correct part for your car, try looking for a different year or model within the posted range. Such as looking up Dart instead of valiant, or 66 instead of 64.
Users browsing this forum: Amazon [Bot], Google [Bot] and 6 guests
