It is currently Sun Nov 29, 2026 2:56 am
 Post subject: Transporting a slant
PostPosted: Wed Jun 19, 2013 9:50 am
Hey guys,
As some of you know, I am likely in need of a new block. I have found one somewhat near by but far enough that I don't want to drive the hemi powered ram all the way there...not so nice on fuel.
My question is, will a slant fit in the trunk of a reasonably sized car? I would pull the manifolds off so it could lie on that side.
It's from an 84 truck though...so hydraulic lifters right? Does it matter if they are oriented incorrectly? I remember hearing something about that somewhere, sometime.
Thanks for the info guys!
 Post subject: Lol
PostPosted: Wed Jun 19, 2013 10:08 am
A used engine will make a mess in the trunk even after draining from fluids puddled in the corners and passages. If you lay down a trap and some heavy mill plastic sheeting it might not be so bad but you will have to work out the physics of getting the block out of the trunk with the engine lift if it "settles" on it's side in an awkward position.
That being said, I used to transport my slant parts and block to the machine shop in the back of my duster. It's easier if the block is mostly disassembled...(a lot easier if it's just an unloaded block to get it over the rear panel lip...)
Just for comparison one of my friends used to go to a local junkyard back in the day and grab a 440 replacement for another friend's challenger during drag season...The yard would use the fork lift to scoot it into the back of his pinto station wagon, and off we'd go to do a RB swap...then he'd blow it up and we'd do it again 4-6 weeks later...
PostPosted: Wed Jun 19, 2013 10:13 am
Lol, so I guess fitting it in there isn't really the issue. Maybe it might be worth it to just use the truck since it'd be easy to get it in and out of the box.
If the fluids are drained and plugs replaced though, it shouldn't make that much of a mess right? Where will the oil and such come out?
 Post subject: Re: Transporting a slant
PostPosted: Wed Jun 19, 2013 10:16 am
...I am likely in need of a new block. I have found one somewhat near by but far enough that I don't want to drive the hemi powered ram all the way there...not so nice on fuel.
This depends on two things- how big is the trunk and how stripped will the motor be? A bare block will probably fit in the trunk of most cars. a fully dressed truck motor (with the deep truck oil pan) with only the manifolds removed will not fit in small or compact cars, and may have trouble sliding into and out of mid-size sedans.
All lifters, whether hydraulic or mechanical, once installed and run on a particular lobe of the camshaft, must always be returned to that lobe on the camshaft since a wear pattern sets in on the lifter bottom. To avoid difficulty, just leave the valve train assembled (head on block, rocker arm shaft bolted to head, pushrods holding the lifters against the cam lobes) during transport.
Any chance you can tow one of those lightweight Harbor Freight trailers behind the car to carry the slant?
 Post subject: It..
PostPosted: Wed Jun 19, 2013 10:21 am
Unless the slant is tipped on it's nose and the water pump removed there will still be water in the cooling jacket. If the oil pan is removed you won't have to worry about left over in the oil pan, but there will some in the oil galley, oil filter is not removed, and pump cavities (There will be residual oil on the crank, block walls, lifter gallery also, just drips...but if it's not your car...)
In a truck it's easy, just put a set of blocks under the rails of the oil pan, or set the oil pan in a spare tire and rim, put a block under the oil pump, then use a rope to secure it side to side in the truck bed..(I even did it without the rope on a 50 mile drive the engine didn't move or tip over...just make sure the blocks are well placed and don't give it room to tip over.
PostPosted: Wed Jun 19, 2013 10:23 am
I'm hoping to be able to use my buddy's van, in which case I wouldn't be concerned at all about fitting it in, but I may end up going in a ford Taurus instead...fairly large trunk.
In terms of the lifters, I just meant having the engine laying on its side. I remember someone being concerned about having an engine upside down on an engine stand for an extended period of time with hydraulic lifters. Can't remember if it was actually a problem or not.
I'm somewhat concerned about getting the engine back out of the car. It would be okay to lift it in with a few guys but it will be a lot more difficult to pull it back out I think. Not sure if I'd be able to get an engine hoist over it with the trunk in place either.
PostPosted: Wed Jun 19, 2013 10:32 am
As it turns out, the guy has the engine and trans loaded onto a pallet already. Ill just take the dodge and he can load it right into the truck. The extra fuel is worth the convenience this time I think.
PostPosted: Wed Jun 19, 2013 10:55 am
What can happen if this is not done correctly? I did not keep mine in particular order when I removed and cleaned them. Is there a way to tell if they are going to cause an issue, look out for them not spinning?
1978 4 door Dodge Aspen, Super Six
PostPosted: Wed Jun 19, 2013 10:56 am
I suggest using the truck or van. I know a standard size pallet will fit through the back doors of a Dodge van, and it should fit in the bed of pickup.
PostPosted: Wed Jun 19, 2013 11:02 am
The van is a Honda...not sure if its wider or narrower than a dodge van.
I'd rather not find out the latter when I get there so ill just go with the truck lol.
PostPosted: Wed Jun 19, 2013 11:23 am
I see, so "The Fit is NO!" :lol:
PostPosted: Wed Jun 19, 2013 1:10 pm
I carried my engine back and forth to the machine shop in my wifes Toyota Highlander. Cherrypicker in and out. I did make a wooden cradle to hold the engine from rocking around, and wrapped it in a dollar store blue tarp to get it there. It should fit in an Odessey.
1964 Dart GT
PostPosted: Wed Jun 19, 2013 3:29 pm
Crude, but does the job. Thrown together with scrap plywood, screws and Tite-Bond glue.
obliquely-inclined state of mind
PostPosted: Wed Jun 19, 2013 4:05 pm
Car Model: '23 T-bucket
Best case scenario; you put break-in lube on both the cam lobes and lifter bottoms, and it works, wearing in new patterns for the misplaced lifters. (I wouldn't count on this happening)
Worst case scenario; even with break-in lube and break-in oil, you destroy at least one lobe and lifter in the first 20-30 minutes of running, then get to pull the engine again, tear it down and redo everything right the second time around.
You wipe a lobe off the cam or tear up a lifter bottom, and the resulting metal particles make thier way through most of the engine, quite probably tearing up the rod, cam and main bearings in thier scenic trip. (I would count on this happening.)
Sorry to give you bad news, but those are the unfortunate realities of the automotive hobby.
Roger
PostPosted: Wed Jun 19, 2013 7:18 pm
So, having removed the lifters, the solution is new lifters?? New cam? Are the cam lobes harder than the lifters, so lifters are all that's needed?
I hope I never make that mistake, but the right info is always nice.
BC
