It is currently Sat Nov 28, 2026 12:41 am
 Post subject: 5/16 push rods
PostPosted: Wed Jun 26, 2013 1:17 pm
Has any body tried using 5/16 push rods in the 225, for high performance use?
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
 Post subject: Yep...
PostPosted: Wed Jun 26, 2013 1:49 pm
Several people have done so without mishap, but if the spring rate and rpm overcomes the material in the pushrod they will flex and if stressed they will bend/fold. I bent a couple mocking up one of my last motors lower performance mills due to the stiffer springs I was using, before they gave out I noticed they were flexing and I was losing some lift at the valve because of it, since I was going to go with custom rods because of the amount of adjustment left at the rocker, I opted for the 3/8" rod with a little thicker wall just to be safe and get all the lift the train was supposed to impart.
PostPosted: Thu Jun 27, 2013 8:27 am
Good to know about, I suspect the 170 to be more safe with the shorter rods, I'll stick to 3/8.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 4 guests
