| 5/16 push rods https://slantsix.org/forum/viewtopic.php?t=52499 |
| Author: | icepaddles [ Wed Jun 26, 2013 1:17 pm ] |
| Post subject: | 5/16 push rods |
Has any body tried using 5/16 push rods in the 225, for high performance use? |
| Author: | DusterIdiot [ Wed Jun 26, 2013 1:49 pm ] |
| Post subject: | Yep... |
Several people have done so without mishap, but if the spring rate and rpm overcomes the material in the pushrod they will flex and if stressed they will bend/fold. I bent a couple mocking up one of my last motors lower performance mills due to the stiffer springs I was using, before they gave out I noticed they were flexing and I was losing some lift at the valve because of it, since I was going to go with custom rods because of the amount of adjustment left at the rocker, I opted for the 3/8" rod with a little thicker wall just to be safe and get all the lift the train was supposed to impart. -D.Idiot |
| Author: | icepaddles [ Thu Jun 27, 2013 8:27 am ] |
Good to know about, I suspect the 170 to be more safe with the shorter rods, I'll stick to 3/8. |
