It is currently Thu Nov 26, 2026 9:59 am
 Post subject: Choke Thermostat
PostPosted: Sun Jul 07, 2013 8:29 pm
So I have searched a few times and I can not seem to find a definite answer.
I have a super six setup with a Carter BBD. Are the mechanical choke thermostats no longer available? If not what is a part number. Second if they are gone is the Carbsonly electronic conversion setup the other answer?
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Sun Jul 07, 2013 9:00 pm
Carbs Only should be your first choice anyway since it is a better design than the original equipment. If you can't find a stock choke thermostat or a carbs only choke thermostat, there is always a manual choke.
 Post subject: Yep...
PostPosted: Sun Jul 07, 2013 9:04 pm
They have been discontinued, and NOS is the only source. Per Reed, there is an electrical substitute that works better than stock, and manual is a cheap and easy install (I think I bought a kit at the local auto parts store for a whopping $10, knob, wire, and bracket for the dash.)
PostPosted: Sun Jul 07, 2013 9:14 pm
I have a new factory unit that I do not need and will sell to you at cost. PM me if interested. :wink:
. . . there was good sport at his making.
PostPosted: Mon Jul 08, 2013 9:38 am
I got a new one from RockAuto last winter. Works fine.
 Post subject: Interesting.
PostPosted: Mon Jul 08, 2013 10:21 am
Looks like Rock Auto has SMP CV230 on the list...for $15.97, but SMP's catalog no longer lists these...knowing that RockAuto does get old stock on an occasion, you might get lucky...
