It is currently Mon Nov 23, 2026 1:09 am
PostPosted: Mon Jan 14, 2013 1:54 pm
Is 45 to 50 psi an acceptable oil pressure reading for a 160 hp Slant?
PostPosted: Mon Jan 14, 2013 1:58 pm
from my understanding thats more than enough if i recall right the rule is 1lbs for every 100rpm
trying to keep it low key here in my Valiant200
PostPosted: Tue Jan 15, 2013 8:25 am
45-50 psi is excellent.
PostPosted: Mon Aug 05, 2013 8:47 am
With my mechanical gauge I read 49 psi constant. No heavy fluctuation with engine at full temp or high speed? Why would that be? or is that normal on a rebuilt engine? (right at 500 miles on it) Running Rotella 15w-40 right now(100+ degrees in Texas), switching to 10w-30 on initial change.(and will run 10w-30 here on out)
1964 Dart GT
PostPosted: Mon Aug 05, 2013 9:31 am
On my truck the needle goes just above the 3rd notch on the gauge and will fluctuate a little below the 3rd notch while driving...I'm wondering if that's reasonable oil pressure?
I assume that each notch on the gauge maybe 10 psi of pressure but i'm not sure?
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
Users browsing this forum: Google [Bot] and 11 guests
