| Crank Gear https://slantsix.org/forum/viewtopic.php?t=52885 |
| Author: | 63dartconv [ Mon Jul 29, 2013 3:49 pm ] |
| Post subject: | Crank Gear |
How far does the crank gear need to go on? I cant find this in my manual? |
| Author: | robertob [ Mon Jul 29, 2013 4:26 pm ] |
Should go on until it bottoms against the shoulder on the crank. Are you talking an aftermarket gear? Some of them are too tight - I had my machinist hone mine out so that it would go on all the way. This is a rollmaster set... |
| Author: | DusterIdiot [ Mon Jul 29, 2013 5:16 pm ] |
| Post subject: | Lol... |
Quote: Are you talking an aftermarket gear? Some of them are too tight - I had my machinist hone mine out so that it would go on all the way.
Even on the Rollmaster sets, I've never had a problem getting them to seat all the way on the crank snout after 5 minutes heating up the gear with a mapp gas torch (now taking the Rollmaster gear back off leaves a lot to be desired).This is a rollmaster set... FYI, if you are using a large socket or piece of pipe and using a hammer to seat the crank gear, your #3 bearing will need to be replaced before doing any more assembly. -D.Idiot |
| Author: | 63dartconv [ Mon Jul 29, 2013 8:17 pm ] |
Why just number 3? And what does it do? |
| Author: | DusterIdiot [ Mon Jul 29, 2013 8:42 pm ] |
| Post subject: | Thrust Bearing |
That's the thrust bearing for the engine...It takes enough abuse doing it's job, hammering on an installed crank is a sure way to put the crank end play out of spec and trash this bearing. |
