It is currently Mon Oct 26, 2026 1:25 am
 Post subject: 2 barrel intake linkage
PostPosted: Fri Mar 21, 2003 1:40 pm
I have a 65 dart 225 automatic. I just picked up a super six set-up from a 78 dodge aspen i got it with all the linkage. I was wondering if anybody had made a similar swap and how to set up the linkage since the styles are different or is this a custom job. if it is custom then is there a method to follow for the kickdown linkage adjustment and or configuration. any help would be great thanks. :?: :?: :?: :?: :?: :?:
mopar n'uff said!!!!!!!!!
PostPosted: Fri Mar 21, 2003 2:55 pm
I'm about to do the same on my 65 dart. I've been told to use the gas pedal from the donor car also. It's a hanging type of pedal, and this swap will make it much easier to do. Hopefully you grabed the gas pedal also. Perhaps someone will elaborate more on this topic.
65' Dart. A work in progress..
______________________
Joe
