It is currently Mon Oct 26, 2026 8:34 am
 Post subject: advance timing?
PostPosted: Sat Mar 22, 2003 11:33 am
I'm convinced that all you /sixers don't set the timing at 0 tdc, so how do you advance it more than the hold down will let you. The only thing I haven't tried is removing the oil filter to loosen the other bolt on the hold down. Will this allow me to advance the timing past where it is now, since I'm at the end of the slot in the hold down? I would really like to stop that embarassing dieseling and maybe release a touch more power.
PostPosted: Sat Mar 22, 2003 3:12 pm
Yes, loosening that other bolt will allow you more range. You can also pull the dist (mark rotor position) and move it one gear tooth.
 Post subject: Advacement advice
PostPosted: Sat Mar 22, 2003 4:00 pm
Heres a tip, while you have distributor out, replace roll pin on gear with cotter pin, had one fail with the results of a destroyed gear and scored distributor shaft.
PostPosted: Tue Mar 25, 2003 9:54 am
thanks for the tips. I going to try that out now. I've had this thing running only for a week or so and am still learning about the /6 motor.
have a homebrew
Users browsing this forum: Amazon [Bot] and 5 guests
