It is currently Mon Oct 26, 2026 9:28 am
PostPosted: Sat Mar 22, 2003 9:21 pm
Hello, all.
I hate that my first post on here is one begging for help, but I guess that is how it has to be.Here is my problem, I hope someone can help me out a bit:
I just converted my '65 Dart /6 to electronic ignition. Prior to the change, it seemed to run pretty strong, but now I am having major probs. I set the distributor back in with the rotor pointing at #1 after finding TDC, but the car starts sporadically and almost never without spitting back through the carb in some way. I have a lot of experience with sb Mopars, and have NEVER had so much trouble getting a car to start smoothly. I am sure part of my problem is the new Carter 1BBL carb, which I am still trying to dial in, as there were no fine tuning instructions included with the carb. I just want to be able to start it again without probs, and keep it running, like it did before. I am using a brand new electronic dist, chrome control box, and a MP wiring loom on a '65 /6 with new carb, plugs, wires, cap, and rotors.
Thanks,
Steve Martin
PostPosted: Sat Mar 22, 2003 10:20 pm
it sounds to me like its off 180 degrees
86 dodge ram w-150
4.10's 4 speed manual
4 inch lift 36's wrapped around weld 15x10 typoons , bored .030, shaved .060, ported, headers, 4-barrel 500 cfm carb, clifford intake& headers, isky racing springs and cam, MP electronic igin,
PostPosted: Sun Mar 23, 2003 5:08 am
I am guessing it is one of these things:
- timing way off (off a gear tooth on dist shaft).
- you have the inductive pickup wires to the dist reversed (I did this once)
- you need to replace your voltage regulator with a newer transistorized one to power the ECU propoerly (most replacement VRs are this style now).
Happy hunting,
PostPosted: Sun Mar 23, 2003 4:47 pm
Well, I think I managed the problem, and I feel like quite the airhead for not recognizing the PROBLEMS earlier. I appreciate the help I did receive, though, and I hope that I can pass some info on at some time, as I learn more about the /6 in my restification project '65 Dart.
