It is currently Sun Nov 22, 2026 6:50 am
 Post subject: '66 Plymouth Valiant
PostPosted: Wed Aug 14, 2013 4:01 pm
Car Model: 66 Valiant 200
I have a broken rear glass. I know the windshields are the same for '63-'66, but I don't know about the back window. I found a '64 I can take the glass out of but I need to know if it will fit.
Washington, Jefferson, Twain, Luther, King, Peewee Herman.
PostPosted: Fri Aug 16, 2013 4:04 pm
your screwed-- 1966 only (NAGS db3566)sedan ht & 4 door valiants only...
different #'s for 63-65 valiants & 63-66 darts,
according to hollander manual.
Lawrence
PostPosted: Fri Aug 16, 2013 4:19 pm
I've never had any luck finding a '66 Valiant rear window replacement gasket either, which you pretty much need if your old one is hardened up and brittle and you want to do a proper paint job and redo the headliner (which tucks under it).
Sucks...
obliquely-inclined state of mind
PostPosted: Sat Aug 17, 2013 1:51 pm
Site Admin
Check with Wildcat. Tell them your a slant six dot org member. They have a couple good ones. Quote was $150-175. Shipping will be another matter.
503 668-7786
CJ
