'66 Plymouth Valiant
https://slantsix.org/forum/viewtopic.php?t=53057
Author:  Tireshredder [ Wed Aug 14, 2013 4:01 pm ]
Post subject:  '66 Plymouth Valiant
I have a broken rear glass. I know the windshields are the same for '63-'66, but I don't know about the back window. I found a '64 I can take the glass out of but I need to know if it will fit.
Author:  VDART [ Fri Aug 16, 2013 4:04 pm ]
your screwed-- 1966 only (NAGS db3566)sedan ht & 4 door valiants only...
different #'s for 63-65 valiants & 63-66 darts,
according to hollander manual.
Lawrence
Author:  Red [ Fri Aug 16, 2013 4:19 pm ]
I've never had any luck finding a '66 Valiant rear window replacement gasket either, which you pretty much need if your old one is hardened up and brittle and you want to do a proper paint job and redo the headliner (which tucks under it).
Sucks...
Author:  ceej [ Sat Aug 17, 2013 1:51 pm ]
Check with Wildcat. Tell them your a slant six dot org member. They have a couple good ones. Quote was $150-175. Shipping will be another matter.
503 668-7786
CJ
