| replacement battery cable end ? https://slantsix.org/forum/viewtopic.php?t=53064 |
| Author: | USAJon [ Thu Aug 15, 2013 2:55 pm ] |
| Post subject: | replacement battery cable end ? |
I see there are some screw cable ends on ebay by accel . my stock end on the positive is craked from misuse..any one ever used such and item ? http://www.ebay.com/itm/New-Accel-1861- ... 99&vxp=mtr |
| Author: | xjarhead [ Thu Aug 15, 2013 9:10 pm ] |
I like the military style clamps here http://www.prime4x4.com/shop/OffRoad-El ... erm001.htm and the covers that go with them. It makes it easier to make up your own cables with soldered rings on the ends. The boots also available here http://www.remybattery.com/terminal-pro ... ector.aspx Dave |
| Author: | emsvitil [ Thu Aug 15, 2013 9:19 pm ] |
I put copper lugs on the cable. Then bolt the lugs to a brass terminal. |
| Author: | Sprag [ Sat Aug 17, 2013 1:45 pm ] |
I also use copper lugs on the cables. Then I bolt the lugs to a side-terminal battery. Connections remain exposed just like the good old days, but now the top of battery can be safely used as a place to set down a tool and your beer. |
| Author: | SlantSteve [ Sun Aug 18, 2013 3:20 pm ] |
I have never used those screw in clamp style terminals but I think they would work fine as long as you have the correct gauge wire.I personally use the solder type terminals,better all round in my book. |
