It is currently Sat Jun 20, 2026 4:35 pm
PostPosted: Thu Aug 15, 2013 2:55 pm
I see there are some screw cable ends on ebay by accel . my stock end on the positive is craked from misuse..any one ever used such and item ?
http://www.ebay.com/itm/New-Accel-1861- ... 99&vxp=mtr
slant six's RULE!
http://www.usajon.com
PostPosted: Thu Aug 15, 2013 9:10 pm
I like the military style clamps here http://www.prime4x4.com/shop/OffRoad-El ... erm001.htm
and the covers that go with them.
It makes it easier to make up your own cables with soldered rings on the ends.
The boots also available here http://www.remybattery.com/terminal-pro ... ector.aspx
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Thu Aug 15, 2013 9:19 pm
I put copper lugs on the cable.
Then bolt the lugs to a brass terminal.
PostPosted: Sat Aug 17, 2013 1:45 pm
I also use copper lugs on the cables.
Then I bolt the lugs to a side-terminal battery.
Connections remain exposed just like the good old days, but now the top of battery can be safely used as a place to set down a tool and your beer.
1966 Coronet Deluxe
PostPosted: Sun Aug 18, 2013 3:20 pm
I have never used those screw in clamp style terminals but I think they would work fine as long as you have the correct gauge wire.I personally use the solder type terminals,better all round in my book.
