It is currently Tue Jun 16, 2026 7:21 am
PostPosted: Sat Aug 17, 2013 6:26 am
Last night, my '65 Belvedere's headlights and interier lights were a little dim and the wipers were running a little slow. It got a little worse when I turned the fan on. While this was happening, the amp gauge needle was a little off center towards the discharge side. At one point, I pulled over and looked under the hood and could see some sparking inside of the generator. I had also been driving for a couple of hours.
This morning the conditions are still the same but the generator isn't sparking. Since rebuilding the engine, I've replaced the voltage regulator (damaged during motor install) and the ballest resistor (for the heck of it). The battery is fairly new and in good condition.
Here's the main question: I've heard that one should "polarize" a voltage regulator during replacement. Should I have done the same? Is this what is causing my issues?
PostPosted: Sat Aug 17, 2013 7:36 am
When you have a generator" you should polarize the system.
You do not have a generator on your 65 Mopar, you have an alternator. You should NEVER polarize an alternator system. You need to trouble shoot the system to find the problem. As a WAG, I think the brushes might be bad in the alternator.
PostPosted: Sat Aug 17, 2013 8:55 am
Thanks for the info. I thought that it looked like an alternator but I've "heard" that alternators have the regulator and the balast resistor built into it. So I've learned something new.
Luckily, these alternators are not too expensive so that may be the answer to my problem.
Thanks for the help.
PostPosted: Sat Aug 17, 2013 9:23 am
6 Pack Dart
Cheao fix, replace brushes, can be done with alternater in place. Just have to remove screws that hold them in (look at where the wires are atached) just don't loose the washers.
Richard
