It is currently Sat Nov 28, 2026 9:46 pm
 Post subject: Cant get a spark
PostPosted: Mon Sep 02, 2013 5:29 pm
So i am having trouble getting my 72 scamp with a slant six to start. I cant get any spark to the distributor. I already replaced ignition coil, cap, ballestic ressistor and wires, points and condensor in distributor. I am getting the 12v to coil when trying to start but no spark. I tried testing the coil while starting the car using a screw driver to get spark, but no luck. Someone told me to replace the distributor and than it should all work . Even if the distributor is bad wouldnt i still get spark at coil right ? Also i have to try and start the car in nuetral, could that be the problem ? Could the timing being off make it not spark ?
1972 Plymouth Scamp with a slant six
PostPosted: Tue Sep 03, 2013 5:53 am
You need to test the coil while it is disconnected from wiring harness. Here is an explanation of how a breaker point ignition system works.
PostPosted: Tue Sep 03, 2013 4:57 pm
I just went thru this with my truck...i don't know if you've read thru my experience but here's the link to the post
http://www.slantsix.org/forum/viewtopic.php?t=53162
On my truck it has the electronic ignition with the magnetic pickup coil and my problem ended up being that the clip holding the pickup coil plate assembly together had lost it's tension and the pickup coil had play in it...which caused the air gap to be too big to send a spark to the plugs
I'm going to get a spark tester tool. You can get them as cheap as $3.99 on sale at harbor freight to help me next time with a spark ignition problem...i sure did get a good education this time around
1984' Dodge D150 Utiline Bed
Slant 6 225, Holley 1920 Carb
A833 4 Speed O/D Transmission
PostPosted: Wed Sep 04, 2013 6:33 pm
So where would i buy a distibutor from ?
PostPosted: Wed Sep 04, 2013 6:38 pm
6 Pack Dart
Send me your address by PM and I will send you a spring.
Richard
PostPosted: Wed Sep 04, 2013 6:41 pm
and thanks for the info.......
