It is currently Mon Oct 26, 2026 9:28 am
 Post subject: Carter choke options
PostPosted: Mon Mar 24, 2003 2:58 am
:?: Could the auto choke from a Carter BBD used on AMCs and Jeeps be used with minor mods when a stock \6 exaust manifold is not used for Super Six applications on our Mopars.
PostPosted: Mon Mar 24, 2003 9:26 pm
Come on. Someone who has converted over to headers must have thought about trying this.
PostPosted: Tue Mar 25, 2003 9:15 am
Are we talking about the "round, black pod" that is used on many of the "brand-X" cars?
Some of these run a copper heat tube up to the pod and others are electriclly heated. Either one should work fine as long as it is hooked-up correctly, no reason why you can not use one.
PostPosted: Tue Mar 25, 2003 8:53 pm
Thanks Doc. I'll hopefully have the funds I need for some dual Dutra duals in a month or to. I just wanted to know if there is another option than going with a manual choke. Thanks again Doc.
