It is currently Sun Oct 11, 2026 11:02 pm
PostPosted: Fri Sep 20, 2013 10:49 am
installed a new torn'd header gasket/tried some hi temp permitex sealent but # 4 cylinder spits .hooker headers.
have spare gasket new untorn
can the car be driven more 20-40 minutes without valve damage?
slant six's RULE!
http://www.usajon.com
PostPosted: Fri Sep 20, 2013 6:14 pm
are you concerned abouit a small leakage allowing under hood temp air to rush in to an exhaust valve and cause the valve to warp?
you want to fix the leak, so you are not exposed to the CO that gets by the fire wall,,
if you are woried about the valves,,allow the engine to idle 10 minutes or so after a hot run,, to balance out the temperatures in the engine prior to shutting it down,, but fix exhaust leaks for your benefit.
Users browsing this forum: Amazon [Bot] and 19 guests
