| GM 3 pin coil? https://slantsix.org/forum/viewtopic.php?t=53480 |
| Author: | kxracer728 [ Mon Sep 30, 2013 5:40 pm ] |
| Post subject: | GM 3 pin coil? |
I need to know which pin is the +, - side of the coil? One is suppose to be used as a tach...
| Author: | Chuck Valiant [ Mon Sep 30, 2013 6:11 pm ] |
I googled "mopar hei conversion" clicked on images and found a bunch of diagrams, they might help. |
| Author: | kxracer728 [ Tue Oct 01, 2013 8:06 am ] |
I found this pic... ![]() Circuit labeled A -Pink Wire: Power (12 V) Circuit. Circuit labeled B -White Wire: Tach Signal for the Tachometer in the Instrument Cluster if equipped. Circuit labeled C -White with Black stripe Wire: Switching Signal Circuit. This wire (circuit) comes from the Ignition Module. From this site... http://easyautodiagnostics.com/gm_icm_t ... stic_1.php So, if i'm going to use the original wiring harness coil 12v + for the start, run source i connect it to (A) on the coil and (B) on the HEI module and connect (C) from the coil to (C) on the HEI module? ![]() The HEI Electronic Ignition Retrofit How-To is a "little confusing" http://www.slantsix.org/forum/viewtopic ... 2ad42d5243 ![]() If you look at the article it say's: If you use this combination coil/module assembly, the original coil has three terminal pins: A) is the coil's primary (+) terminal; gets ignition-on 12v and is connected to module pin "A". B) is a tachometer signal output. Not used if you don't have a tach. C) is the coil's primary (-) terminal, goes to module pin "D" I'm not sure why he's saying module pins "A" and "D" It looks like he is giving the wiring for the 4 pin HEI module that comes with the coil pack...Is this HEI module usable? Look at the pic ![]() In the article he say's "The newer style module included with this setup won't work with the Mopar distributor; it's looking for a 0-5 volt square wave, and that's not the kind of signal the Mopar distributor puts out. You can use the early type (4-pin) module—part numbers specified above in the discussion of module selection" Here's a pic of the setup he's talking about...
| Author: | Reed [ Tue Oct 01, 2013 10:07 am ] |
The article is a little confusing, especially on this point, and you found the most complicated wiring diagram for the HEI conversion I have seen yet. I drew up a wiring diagram of how I believe you need to wire the HEI module and the coil you are using. I left out the relay wiring for simplicity, but I do encourage you to use one. ![]() Sorry about the hand shadows. I had to use my phone to take a picture because my scanner is a PITA to use right now. |
| Author: | kxracer728 [ Tue Oct 01, 2013 11:36 am ] |
Thanks for the response and drawing the diagram...Reed That helps confirm what i was thinking! It will be the same setup i have now but with a higher voltage coil...i gapped the plugs to .050 yesterday I checked the coil it doesn't have any A,B,C letters from what i read the ignition coil connector has the A,B,C lettering. Quote: I left out the relay wiring for simplicity, but I do encourage you to use one.
I'm going to work on adding a relay soon...
| Author: | Reed [ Tue Oct 01, 2013 11:48 am ] |
Quote: Thanks for the response and drawing the diagram...Reed
Sounds good. The plug should only go on the coil one way, so use the "A-B-C" on the plug to guide your harness fabrication.
I'm going to work on adding a relay soon... |
| Author: | Junior [ Tue Oct 01, 2013 1:06 pm ] |
does anyone have a part number for the plug that goes to the coil shown? |
